fockerunleashed
Hi, have been away from the PC scene for a while.
Now need help building a new rig for office from scratch. Its main use is going to be for a designer to design on Corel / Illustrator / PhotoShop and interface with our Laser Machine in addition to regular office work.
The budget is a problem, yet need flawless performance on Corel / Illustrator / PhotoShop. All help will be much appreciated.
Thanks!
Have answered the questions as best I could. Nothing is fixed and is completely flexible.
Questions
Thanks!
Questions
- What is your budget?
- 35K or lesser the better.
- None, completely new rig.
- None, need to buy everything.
- None as yet.
- No, final config.
- Delhi (Nehru Place most likely)
- No
- Main use is designing on Corel / Illustrator / PhotoShop and interfacing with our Laser Machine
- Regular Office Work (Word, Tally, etc...)
- None
- None
- Desktop - 1920x1080
- No
- Windows 10 / 7 ?
