Budget 31-40k Home PC for browsing and movies
fractal
  1. What is your budget?
    • 40K
    • No proper system. Using an old laptop
    • Will recycle a Seagate 500 Gb HDD
    • Will recycle 2x2Gb Corsair value RAM 1333 MHz
    • CPU - Intel I3 4130 (Rs 7K)
    • Motherboard - Any compatible
    • GPU - Onboard
    • PSU - Corsair CX 430W (Rs 2.7K)
    • KB/Mouse - Logitech (<1K)
    • Monitor - LG 23MP55HQ (11.5K). Requirement is a non-glossy Monitor
    • Cabinet - Any (about 2-3 K)
    • RAM 4Gb 1600 MHz Corsair
    • SSD 120 Gb Samsung Evo for boot drive or Any other SSD
    • Bangalore
    • Open to online purchase
    • No
    • Browsing - Multi tab
    • Youtube HD streaming
    • Desktop Processing
    • Watching HD movies
    • None
    • No Gaming at all
    1. Desktop - Full HD
    • No
    • Windows 7 64 bit
    • Linux via pendrive
Are only Z97 and H97 series motherboards (which are expensive) compatible out of the box with Intel I3 4130
Other chipsets will need a bios update?
And for a bios update I will need an older gen CPU?
  • CPU - Intel I3 4130 (Rs 6.9K)
  • Motherboard - Gigabyte B85M-D3H (Rs 5.2k)
  • RAM - Corsair Vengeance 4GB 1600Mhz (Rs 2.8k)
  • KB/Mouse - Logitech MK200 Combo (Rs .8k)
  • Monitor - LG 23MP55HQ (Rs 11.5K)
  • Cabinet - Deepcool TESSERACT (Rs 2.8k)
  • HDD - WD Caviar Blue 500GB (Rs 3k)
  • GPU - Sapphire R7 240 1GB (Rs 5.1k)
  • TOTAL - Rs.40,800.
i3 4130 is one of the original Haswells launched last year, not the Haswell refresh models, so should work fine out of the box even with an 8 series chipset board.
If you're looking at a Haswell refresh proc, ECS has stated that you need an older CPU to update the BIOS.
I'm not sure why you need the R7 240, since quick sync does a fine job at decoding as well.
