HailStonE said:Do keep in mind Activa has better acceptability in masses than Dio when it comes to resale value...
Look at Aviator as well if you want to compare... Personally I have tested Activa & Dio. Activa has better riding position than Dio, better build as well... try them beforehand...
_pappu_ said:i have both, so :bleh:
activa::
metal body
bit more comfy to drive, due to position
weight makes the suspension nice and soft
underseat box has a little more space, dio may not fit a fullsize helmet but this one will
dio::
fibre body
very stiff suspension
i am tall, and while cornering my legs hit the handlebar
amol_cool said:Plus ONE for all the above
Also DIO has a stationary front light which can be pain in the ass sometimes in night!
_pappu_ said:what do you mean
the angle on the front light can be adjusted on the dio, the screw is just under that beak type portion
that said, the active headlamp is better than the one on the dio with regards to brightness and a nice spread of light
