vebk
I am in the process of upgrading my computer. Have got a new graphics card, will be getting some RAM, and a new hard drive as well. Am planning on getting into gaming, so am thinking of erasing everything from my current hdd and reinstalling Windows so as to give it a nice clean start. The drive is now almost a year old and is unpartitioned. I heard that it's better to partition the main hdd so as to create a separate partition for the OS (and program files (?) ).
So my plan is roughly this:
1) Install the new hdd (250GB). Here I need help as to how should I partition this if at all. I will be keeping music, pics, movies etc. on this.
2) Move everything I need for the old hdd (80GB) to the new one.
3) Reformat, and partition the 80GB hdd. Here what partition should I create?
4) Do a fresh install of XP on the 80GB.
So with two fresh, clean drives, new RAM (2 x 1GB dual channel), new graphics card hopefully I can maximize on what my system can pull off in terms of gaming.
Another quick question - Once all this is done, and I start playing games, should I install them to the 80GB or the 250GB?
