I have a Samsung 29inch T.V which doesn't have a headphone port, it has audio out ports.
How can i connect my headphones to the T.V?
I found some stuff at:
Rca Plug: Rca Adapter, Xlr Adapter, Audio Adapter, Rca Connector, Mini Plug, Phone Plug, Banana Plug, Audio Adapter Cable, Adapter Cable
But they are huge varities there and i don't know which is suitable. Basically i need a convertor: One side of which should have 2 male connectors which will plug into the T.V audio out and the other side should have a headphone female port so that i can connect the headphones to that.
Any ideas about which converter should be useful and also some info regarding its availability in Delhi would be gr8.
Thanks in advance.
Thanks in advance.
