How to do basic webpage editing?
Barney_IRELAND
New Member
2
0
1
Hi all
I have been asked in work to manage the department's webpage on the
company website.
I have no training in web page editing or HTML.
Thankfully, it is a simple webpage with no fancy animations,
backgrounds or interactive content. It is just a webpage with
paragraphs about the company, a few photos and some links to other
departments.
Can anyone point me to some basic tutorials on how to edit a webpage?
The way I plan to do this would be to I would edit the pages offline,
show them to management and once approved upload them
to the site admin for uploading to the main company site.
I was going to use Microsoft Word, but it seems a bit "clunky"
Can anyone recommend a better way to edit webpages?
Thanks
Barney
seshu
Jan 18, 2006
626
94
117
teluguthesis.com
how do you access the html files ?
is it through web host panel's file manager or through ftp program (eg. filezilla)
if using ftp then I'd suggest to use a advanced text editor - like notepad++
if file manager at web host panel is used then you can use the editor available there
basic tutorials available at w3schools , siteground ... should be helpful
Crapmypants
Dec 13, 2014
866
343
101
not an expert here but i can safely say that using ms word to edit an html file is what makes people throw their systems out the window.
notepad/wordpad the way to go.
booo
BA BA BA BABANANA
Veteran
Mar 4, 2008
1,768
1,919
403
Colodaro
visual studio express edition is the best tool I can suggest. Intellisense helps a lot for someone who is learning.
