How to test new motherboard for error if any for returning the manufacturer on time for quick replacement ?
Are there any software or hardware solution to check new motherboard for any fault which might occur afterwards.
I need to check this
1) Memory stability..
2) If the system automatically restart
3) The Heat is not giving problem..or display heat plus inform if it is above normal
4) Audio, video, etc
and many more how to do that...
