how to use usb on a wall mounted led? how to do pc gaming on it?
Dishant996
Active Member
138
2
33
Bhopal, Madhya Pradesh
i have a sony klv 32r402a led 32 inch tv. it has 2 hdmi ports and a usb port.
my questions are-
1. how to use usb extension wire on the tv (those wires that are used to connect rear ports on the cabinet)?
i tried to, but the pendrive wasn't detected by the tv. why?
2. i have a pc. it has a external gpu. sapphire hd6670 1gb ddr3. yes, it has a hdmi port. i want to use it on my tv. is my gpu enough or not? can it have any impact on my tv, whatsoever?
RakaKaKaka
Jun 28, 2016
813
202
56
when directly connecting pendrive TV is detecting it ? could be a bad/loose wire. GPu is enough depends on what you gonna do with it. any gpu will connect to a TV to duplicate/send the signal.
xman0752
Banned
96
9
21
kolkata
Are you using a USB extension wire ? try connecting any normal mp3 USB directly and see if it gets detected or not .
