Leshy
HTPC for 20k
1. Q: What is your budget?
- 20K
2. Q: Which hardware will you be keeping (component name - component brand and model)
- TV - samsung 55"
3. Q: Which hardware component are you looking to buy (component name). If you have already decided on a configuration then please mention the (component brand and model) as well, this will help us in fine tuning your requirement.
- CPU - any AMD fusion capable of 1080p / also should i consider intel?
- Motherboard - NOT asus must have HDMI
- GPU - none / may think of if i consider intel
- cabinet- any good htpc cabinet the size of 2 dvd players placed one on top of another
- PSU- a good psu
4. Q: What is your intended use for this PC/hardware
- HTPC
- Watching Blu-Ray movies (already have a blu ray drive)
5. Q: Which operating system do you intend to use with this configuration?
- Windows 7 64 bit
- XBMC
