Intel i7 2500K, its a binned chip which can do above 56X, havent used the chip for more than 5 minutes which was just to check for the multiplier.
Invoice Available : Yes, Dated 18th June, 2011
Price : Rs. 11500 shipped. Rs. 11400 pickup.
Let me quote what I said in one of the other threads about SB behavior
With Sandybridge, 2500K/2600K, there are max clock limit to every chip. Pushing more volts or cooling does not help even a single Mhz if you reach those max clocks of the chip. Max clocks can be anywhere between, 4800Mhz to 6000Mhz. What I am selling here is a CPU, with adequate cooling, you can get above 5400Mhz but below 5500Mhz. Since I have just done a multi test and clock test.
All that I have written above is true for earlier generation of CPU's too like the C2D, Nehalem, Bloomfield, but that limit used to reach only on LN2 so it mattered only to a few of us, difference now with SB is that those limit can be reached by even Water or Top end Air cooling.
Also earlier there used to be good batches etc. which would have fairly guaranteed you a good overclocking chip but with Sandybridge there have been no known pattern to find a good chip, only way is to manually test individual chip.
