OC & Modding Intel E5200 temp at Gigabyte UD3L without overclock
I think the temps are a bit high.. It should be a max of arnd 54-55 degress on stock speeds & stock cooler.. Try reseating the hsf & applying a fresh coat of thermal paste.. Also make sure that the thermal paste is evenly spread b/w the proc & cooler..
but bro,as you know now a days paste is already applied to the bottom of the cooler.i think i need to buy some artic silver paste this time
can you suggest some cheap cooler ??
Temperatures are absolutely normal no need to worry ,for better results make use of 3rd party coolers+120mm fans in cabby for airflow.
check out with the core temps....
try to set it manually......
mine mobo on auto took it till 1.5 after ocing it to 3 ghz which is pretty dangerous....
so i hav set it manually nd now my temps at 3.3 ghz r jst around 60(ran orthos for 30 mins)
