Hi I need some suggestions for iPad 3 cases. I'm confused between front and back or front Smart Cover or back shield like a barely there case with front Smart Cover -- pretty much all the options. I'm confused!
So I need your help in deciding --
Please suggest cases for an iPad 3 with links you think go well.
Constraints ::
--Has to be light weight
--Budget is 3k
--Has to be thin
Looking forward to your support!!
Constraints ::
--Budget is 3k
--Has to be thin
