Amien
Hello,
Not quite sure if this is the right section for this(I was thinking of posting this in the audio section).:-
A friend of mine needs to have his iPod fixed with a new battery. There is also some mono/stereo issue with the earphone jack (which apparently can be replaced as well). Based on this, he has a couple of queries:-
1)Where would be the best place to get this done reliably?
2)How much would a replacement battery cost? ( he says the current battery is a Lithium Ion, 3.7 Volts, 650mAh battery) (Are there better replacement batteries available that are safe for use? Any information on them would be much appreciated. Thanks!
