Laptops laptop cooling pad
lounge
i have got m1330.. need a cooling pad..
hoz belkin? if anyone has used?
how much noise does its fan make?
I know its usb powered.. may be i can use it with charging on.. or is there other good alternatives?
thanks
I use a Cooler Master NotePal Infinite (Website Link) I am satisfied with its performance and it is very effective in cooling my LG P1 PRO Express Dual... It is USB powered, has 3 fan speeds... It has an aluminum mesh on top to dissipate heat better...
i have used belkin cooling pad. its quite good. brings the temperature down by 10-20 degree c. while in mumbai's warm climate it was fine. but in december end in New Delhi its fan gave some noise while starting. it stabilised after few times attaching and detaching from the usb port. reminded me of a FIAT padmini starting up in winter. Guess the fan of the cooling pad will be under pressure in cold weather :S
All i do is Jack up my VAIO on bottle caps, and keep the laptop within the range of the ceiling fan, seems OK to me.
I saw a laptop cooling lit for 400bux at a local stationery, it employed a similar jacking mechanism to what I do :p
Does Belking really make a difference, can it be termed optional ?
