LED HD TV - Suggestions Please
sunny082
New Member
24
0
0
37
Hey Guys,
I'm from Mumbai and planning to buy a LED HD TV - Budget is around 32~35K - 32 Inches will be appropriate as per the room size.
I don't need internet facility in the TV. Please suggest which one shud I go for.. :huh:
Thanks...
Sunny
saurabh.
Member
78
7
21
36
I would recommend LG 32LV3500. The key feature of this model is that it has IPS panel. That means it has wide viewing angle. It does not have internet features but you don't need it anyway. Samsung has a model in similar price range (32D5000PRMXL) but it does not have IPS panel. Sony's equivalent model is 32EX520. But it is costly and I think this one also doesn't have IPS panel. Though I recommend to visit showroom to see the difference. If you are not going to watch full HD content on TV, you can also look for HD ready models. They are cheaper. Also check out flipkart site. Prices there are less than the showroom prices (with warranty). And good that you live in Mumbai because flipkart provides service in Mumbai.
