Liquid cooling from Larkooler : Affordable price with Amazing performance
One more product in our stable ! - Officially imported and Distributed by Buygamingstuff
About Larkooler :
From October 2009, GBU Taiwan proudly represent Larkooler PC cooling products as the sole exporting partner. Larkooler is a new generation cooling system for desktop computers. It is designed with best cooling solution for CPU, Northbridge, Southbridge, graphic card and MOSFET. Larkooer is the most cost-effective PC cooling solution in the PC markets.
we are proud to announce that we are getting Larkooler products in INDIA
MODEL : BA2-241
MODEL : BA2-241
Most Cost-Effective CPU Liquid Cooling
Very High C/P
Supports INTEL LGA775/LGA1156/LGA1366
Supports AMD Socket 754/939/940
Larkooler is a new generation cooling system for desktop computers. It is designed with best cooling solution for the most important component of your PC, CPU.
Package content: CPU Water Block, Pump, Radiator, Tank, Coolant and Tube
Most Cost-Effective CPU Liquid Cooling Kit
Very High C/P
Supports AMD Socket 754/939/940/AM2/AM3
3D Thermal solution adapted, outstanding heat dispersion under very low water flow
Supports most CPU like Intel I7& AMD Phenom II processors
The universal type strengthened backplate not only prevents MB distortion but also has high compatibility for all kinds of MBs
Easy installation due to 2-way tubing design which also enables upgrade to series connection of more water blocks
Highly polished base to ensure excellent surface contact with heat source
Fitting with refrigeration-and- air-conditioning-class structures provides high performance heat dispersing at low noise
Easy installation design and back mounting bracket let DIY'ers enjoy DIY
Specially designed bolts and nuts to prevent tube's looseness and coolant leakage
Pump with refrigeration-and- air-conditioning-class structures provides low-water warning
Steady and silent working
Easy installation design brings more fun to DIY'ers
Details Infor : Specs
PRICE :6750 shipped :clap::clap::clap:
Larkooler Universal High Performance Complete CPU / VGA / Chipset / Mosfet Liquid Cooling Kit
MODEL : BA2-244
Larkooler is a new generation cooling system for desktop computers. It is designed with the best cooling solution for the most important component of your PC, the CPU. This kit includes everything you need to get started. A pure copper block for maximum heat absorption. Tubing and cooling fluid are also included. VGA , Chipset, and Mosfet blocks are also included with a huge compatibility range! Literally EVERYTHING you need is here in this kit.
Package content: CPU/GPU/Chipset/Mosfet Blocks, Pump, Radiator, Tank, Coolant and Tube
Most Cost-Effective Complete Liquid Cooling Kit
Very High C/P
PRICE : 9900 Shipped :clap::clap::clap::clap:
Review : MADSHRIMPS - Hardware Reviews ,Crazy Projects, Modding Tutorials and Overclocking
Getting very limited stock
Coolant extra bottle will cost just 325 bucks more
warranty 2 years
Interested members can Drop me a PM regarding the same
Impressive results from the 10k package considering it includes so many water blocks! Very very affordable IMO.
Only gripe is the GPU kit doesn't include VRM/RAM heatsinks so one may have to invest in a bit more and get the additional heatsinks.
