Locked Phone Memory
Sheriff
New Member
135
2
0
I've got a Nokia 3530. Recently i've ran out of SIM memory for phonebook, so i tried enabling the phone memory.When i tried to do so, it says "Phone Memory Protected" and asks be for a security code. I don't know this security code, so as a result i can not enable the phone memory.
Can anybody give me any ideas on how this code can be bypassed ?
superczar
Veteran
Mar 17, 2005
4,479
572
202
40
Try 1234 or 0000 or 9999 as they are the usual factory set security settings...
If however you bought a used set/ha a changed security code for some reason, then you would need to flash the EEPROM in the set.
Reactions: 1 person
TheMask
Jan 3, 2005
3,732
53
137
^^ adding to that, sometimes it is 12345 too..
BTW, try to copy/move a couple of phone numbers from the SIM card on to the phone. U'll find the option in Phone Book. If it still asks for the code, then try one of the codes suggested above.
~HeadShot~
Mar 15, 2005
1,863
27
111
29
Hey, buddy!
For Nokia handsets, the default code is 12345!
Switch
Veteran
Jan 13, 2005
5,578
336
227
Nokia Security Code 12345... One more reasone why should one read the complete manual...
Sheriff
New Member
135
2
0
I've already have tried 12345 and 00000, they don't work.
superczar said:
Then you would need to flash the EEPROM in the set.
How can that be done ?
Again, how do i do it, there's no option as such, visible now, to do that
