superczar
At the risk of sounding like AK (advocating something while actually doing something else ) , let me pose this question
While I suggest anyone who is trying to get coverage across floors/large area to use a cheap wired AP with the same SSID to extend coverage, the approach does have its own flaws
Primarily
a) Some devices tend to stick to the 1st AP and dont switch to the second one even when you move to a poor coverage for the 1st
b) Bonjour has its own set of issues with multiple APs - Airplay and airprint are often hit&miss across multiple APs
I was wondering if there are any true long range routers or a single AP that can cover my requirement
The router is located in one corner of the ground floor - The ground floor is approx 1400 sqft and a 1000 sqft garden in front - The second floor is approx the same as the first
Current scenario: My current primary router is a D-Link DIR850L (AC1200) which is in one corner of the house
It provides coverage for the ground floor and covers the house area very well but starts fading in & out near the gate and outer reaches of the garden
On the first floor, the DIR850 signal fades away quickly so I have an old Dlink DIR600 mounted on the staircase as a wired AP
The DIR 600 fades out on the corners of the 2nd floor so I have an airport express connected as a wired AP (through a powerline adapter) in the bedroom which also helps extend coverage to the far corners of the garden)
While the above does work, I would gladly switch to a single AP/router solution if I know it would work
The current setup works and I don't want to spend time & money changing to something else that does not server the purpose
Considering you can't return electronics in India (unless defective) so can't really order & try
BAsed on reviews, the ubiqiti unifi AP seems to have got good reviews on range (but some other say that the range is really no better than their existing router)
Any real world reviews from India would help
Also, Any other suggestions?
Primarily
