Looking for a 43 inch 4K TV
indy1811
Veteran
Dec 24, 2006
2,115
291
172
What's your viewing distance? 43 is alright if you'll be sitting 4-6 feet away. Any longer and it's better to get a 49" or a 55" TV. Remember, you can change almost everything about the TV(smart - Chromecast, firecast. Audio - soundbar etc.) except the size and panel quality
meetdilip
Oct 9, 2011
668
105
81
Xiaomi has recently launched 75 inch 4K TV. See whether it will fit your budget or not. As mentioned above, the size of the TV depends a lot on the size of the room and viewing distance.
