Looking for a Router(with built in modem) for VOIP and Gaming.
Sobirvs
Veteran
Mar 20, 2013
1,031
383
127
28
Chrome
So need a router with built in modem (rj45 only not telephone line port)
Currently I am using an entry level netgear with excitel and it's giving me pain for VOIP calls (whatsapp/skype/SIP) and gaming with PS4(with LAN).
* Coverage is not a problem as it is needed for one small living room.
* Excitel is moving to fiber soon and hathway already is , so a router which can support fiber and Ethernet WAN both will be atleast future proof
* latency should be least. I will be playing only fifa 18 on PS4 multiplayer over PSN so need rock stable connection.
* 2.4GHz and 5GHz should both be supported.
* Should support excitel and hathway connections.
most imp is lag free gaming and voip.
Sobirvs
Veteran
Mar 20, 2013
1,031
383
127
28
Chrome
I rather have everything built in one piece. In this day and age, we hardly have room for one rather than 2 and wires. anywyas, bump, anybody can help regarding this?
nimod
Jan 7, 2013
617
354
102
Wait for your service provider to shift to fibre, when they change your router, give them your requirement.
vivek.krishnan
Veteran
Dec 18, 2009
7,469
1,675
303
Ghatkopar, Mumbai
plus.google.com
Its not like its going to occupy a whole lot of space.
If you go with ISP provided routers, they are usually crap. Additionally, I doubt most ISPs except Jio will provide fibre modem, they will give a GPON media converter instead. So still you will have 2 boxes.
puns
Section Mod
Mar 24, 2005
1,350
384
173
New Delhi
router with built in modem (rj45 only not telephone line port) What kind of modem, I have DSL-AC68U it has DSL and VDSL option
How is it ? I am looking for something for Airtel V Fiber cause the Huawei model they have given is not good. All VDSL models seem expensive. Anything in the 5 to 6K range if you know ?
Sobirvs
Veteran
Mar 20, 2013
1,031
383
127
28
Chrome
No Idea. This is just a router and I love it. It has everything I could ask for.
tommy_vercetti
Apr 20, 2006
1,277
197
157
42
Sion/Vikhroli/Airoli/Navi Mumbai
www.boricha.org
This is a really good router, I have used it on DSL, currently running on local PPoE connection, the range is very good, easily able to get range on one floor above, I have no experience of it on VDSL, it is a second hand 5K, got a steal deal from either this or E forum
Reactions: puns
