yes.. your right..Could you tell why do you want this? From the looks of the requirements, you might be looking to build a network router.
In that case, I would suggest to replicate what @cyberwarfare has done, with an AMD APU series board. He is running pfsense, but not using a i350 T4.
are you referring to this post ? #4
If so he does use an 4 port network card..
Just for context, I am currently running pfsense as VM on my server. Which you might be aware has significant downside, the server can't be messed with. Since I am looking to mess around my server I need uninterrupted network so, looking for very cheap way to get a pfsense box(DIY). Before the VM I was running pfsense on LGA775 board, but the damn thing keeps hanging, guessing some motherboard problem( I still have it , planning on reviving it again and giving it a shot) and its only 1 gb ram, need a few more for suricata and other packages also right.. Mind you this all for home play .. so trying to keep it as cheap as possible..
Yes that is the post he is referring to.
If you are indeed building a pfsense box, i suggest that you pick up something similar to what i have, or if you can spend that extra money, get a qotom based system from aliexpress/banggood etc.
My cpu and board cost me about 7ish and the NIC was another 7.5 (quad port). the ram, boot media, psu and case are subjective based on what you want.
Do let me know if you need more help.
OT - Where are you located, and whats the up/down speed of your pfsense box going to be?
Could you please mention the exact motherboard your using.. and are you using a ATX PSU or micro PSU with laptop style charger brick? Does the CPU support AES?
Other than the NIC i have to get everything else, but not looking to shell out more than 7 to 8k.. might be too tight.. but i think i can manage within that range.. But i want to give a shot at the microPSU which is overshooting my budget..
I did consider qotom , but the cost benefit did not make sense to me, which is when i decided to got with a virtual router. Just in case I
I am located in Bangalore...
I have not done any specific speed tests ,i.e, with suricata on or over VPN..
but over normal functionality ,i.e, basic router setup, i get 60-70 down and 10-20 up.. over 75mbps ACT line.. Infact i have to say that though its virtual this has been the most stable router i ever had since ever.. I had asus/tp-link etc.. and all of them had some problem or the other and eventually had to reboot.. This has been on for months without a problem, except recently i had to shutdown due to electricity outage during the recent rains..
Do you both, @cyberwarfare and @vivek.krishnan run on a dedicated setup or is it virtual? Do you use VPN or snort/suricata? If so have you checked the speeds?
It good to know there are ppl trying out diy routers here assuming you guys are put up in INDIA..
Well the limitation is only when we want play around the hypervisor.. I did try esxi, unraid and proxmox.. and of the 3 only proxmox was able to work with gaming VM and pfsense.. With unraid pfsense was big problem and with esxi pass through of GPU for gaming VM was a problem.. thought many other were able to do fine.. Which is why I settled for proxmox.. But to be frank, if I get pfsense out on a dedicated box then i will used unraid.. I somehow like the GUI of esxi and unraid .. but proxmox not so much esp when it is managing storage to the hypervisor..I am not aware of any limitations surrounding the server yet
Is your line rate affected?snort was deployed earlier.
routerOS, but why? pfsense can do what routerOS does..I would be testing with Hyper V, since with 2.4 they have added support. No issues with ESXi anyways, been using over 6 months.
My machine is dedicated to pfsense and routerOS.
I thought ESXi was the most stable.. why are looking to test on hyper-V? any advantages?
Thanks @cyberwarfare and @vivek.krishnan ...
I decided to remain with pfsense as VM and only for firewall ,i.e, IPS pfblocker and other services. Might try other UTM also..
And I am going to get edgerouterX for basic router.. I believe that is best possible way forward.. small, less power and no sound ..
