Konquerror
Well my father want to replace the existing CPU with a new one. The main use of this system is Document Processing like making reports using MS Word. This PC sometimes used for casual gaming. Hence GPU is not a must unless required. He prefers Intel processors over AMD. He would be keeping the existing cabinet. Please suggest a optimal configuration with approximate prices of components.
Q: What is your budget?
15K
CPU - Intel Dual Core 3Ghz
Motherboard - Intel D915GAV
GPU - Intel Integrated Graphics
RAM - Transcend 2X1GB
Monitor - Benq E2220HD
SMPS - Local SMPS (not sure about brand name)
(please mention the rest in above format)
CPU - Intel Core i3 or equivalent
Motherboard - any compatible motherboard
GPU - None (will rely on Motherboard's integrated GPU)
PSU - Not Sure
Yes, it would be final config.
Patna/Online/TE Dealer
No
Light Gaming
Desktop Processing
No
None
1920x1080
No
Windows 7 or Windows XP
15K
PSU - Not Sure
No
Light Gaming
Desktop Processing
No
None
1920x1080
No
