Budget 21-30k Looking for upgrade
iyengar
Active Member
May 27, 2010
451
15
32
41
Questions
  1. What is your budget?
    • Open
    • CPU - Intel Core i3-6098P
    • Motherboard - Gigabyte GA-H110M-S2-CF
    • GPU - AMD RX 460
    • RAM - Corsair Vengeance LPX DDR4 2400 C16 1x8GB
    • Monitor - BenQ GL2450 LED
    • PSU - Corsair HX750W
    • Sound card - ASUS XONAR DX 5.1
    • Case - Cooler Master HAF 922
    • SSD: Samsung 860 Evo 250GB -Primary
    • SSD: Samsung 860 Evo 500GB
    • HDD: WD WD5002ABYS-02B1B0 500GB
    • HDD: Samsung Spinpoint F1 1TB
    • HDD: Seagate Backup+ BK 500GB
    • Not Sure what to dispose
    • CPU - ???
    • Motherboard - any compatible motherboard
    • GPU - ???
    • RAM - ???
    • Yes, will upgrade the following within 3 - 4 years
    • Bangalore
    • Open to online purchase
    • Yes
    • Casual Gaming
    • Browsing Techenclave
    • Desktop Processing
    • Download rig, 24x7 operation
    • Watching HD movies
    • None
    • One Person Shooter
    1. Gaming - 1280x720
    2. Desktop - 1440x900
    • No
    • Windows 10 64 bit
nRiTeCh
If you can see the green dot, I'm online ;-)
Veteran
From your existing stock you should hold on to these items:
Ram
Monitor
Psu
Sound card
Case is also solid as I got similar ones but dont know how good or bad is your case condition (its bulky as well)
Keep both SSDs
Keep this Spinpoint 1tb Hdd unless too old.
Now what you are left to upgrade is only:
Cpu, Mobo, some additional ram & gpu.
Monitor only if you plan for 4k.
Case if you want lightweight and mid atx.
Reactions: iyengar
iyengar
Active Member
May 27, 2010
451
15
32
41
Well I meant, what is/are reason(s) to upgrade ? Is it more gaming performance needed ? Something more resource-heavy work being introduced ?
Just wanted to keep up with the market standard for a guy who uses system for movie experience or play game once in a year like first person shooter genre. Hope you get my point
Crapmypants
Dec 13, 2014
862
336
101
For movies & other basic tasks, your existing configuration is fine. the only constraint would be the first person shooters so i'd suggest a gpu upgrade (like a 1060 or better).
Reactions: iyengar
bssunilreddy
Veteran
Mar 24, 2007
1,989
763
207
40
Nellore
plus.google.com
Budget -58k
Processor -AMD Ryzen 5 2600 -16k
Motherboard -Asus TUF B450 Plus Gaming -10k
RAM -Corsair Vengeance LPX 3000Mhz 8GB -6k
GPU -Zotac GTX 1660 Ti 6GB -26k
Total -58k
Reactions: iyengar
vyral_143
Jarvis
Section Mod
Nov 28, 2011
3,229
1,369
207
香港
Got it. In that case may be get your GPU upgraded first. Your CPU + Mobo and may be RAM can be upgraded in future. IIRC, vedantcomputers had Sapphire RX580 4GB for 14K. You can start from here.
Reactions: iyengar
rahulcnbc
New Member
17
1
3
Delhi
cani have ur cpu n mobo as my intel e7400 is giving me troubles, pls let me know the price, my mobo is <EDITED> delhi. thanks
