Budget 0-20k Low Power HTPC within 10-15k
sunny27
Stig's Indian Cousin!!!
  1. What is your budget?
    • 10-15K
    • 40 Inch Full Hd Videocon LED (as a display) - everything else has to be bought
    • CPU+motherboard+ram+harddrive+GPU+smps+cabinet+wireless keyboard with touchpad
    • May upgrade ram later
    • Mumbai
    • Scouted the TE marketplace - found nothing suitable
    • Open to online purchase
    • Yes/No
    • Basic ms-office/pdf/productivity tools
    • Browsing on chrome with 10-20 tabs open
    • Desktop Processing
    • HTPC - want it to do 1080p/h265 capable playback
    • Download rig
    • None whatsoever
    • None whatsoever
    1. Desktop - 1920x1080
    • No
    • Dual boot Linux and windows
    • Windows 7 64 bit
    • Linux - Deepin OS/Fedora
ASRock QC1500 is the best Mini-ITX form factor motherboard with APU integrated, but most likely available in India this month end as per ASRock Dealer.
Acquired system 2 weeks back-
intel g3220
ecs h81 board
4gb ddr3 1600 mhz kingston
500 gb seagate 7200 rpm drive
circle lil red cabinet with psu
logitech k400r
Netis pci-e w2113 wifi card
All this within 15k.
