Micromax A100 Android phone with 5 inch screen listed on Homeshop18 for Rs. 9,999
Aman27deep
Veteran
Apr 7, 2008
6,487
250
222
Calcutta
www.fluxgaming.in
Although not an official announcement, the appearance of the Micromax A100 has guaranteed that it is an actual phone. It has come up on Homeshop18 as an entry and there it shows that it is out of Stock. The Smartphone will run Android 4.0 and have 512 MB of RAM.
The screen size will be very large at 5 inches (these kind of large phones are usually called phablets), but will only have a resolution of 800 x 480 (PPI of 186) which would clearly mean the images/text/videos won't be as clear as it is on the Galaxy Note, for example. The phone is proposed to include MediaTek MT6577 dual core 1GHz Cortex-A9 CPU under the hood, in tandem with the PowerVR SGX531 GPU.
According to the specifications listen on the Homeshop18 website, the phone will have a rear camera of 5 Mega Pixel, and internal storage will be 4 GB. An expansion slot will be there to expand the storage via MicroSD. It will also be a dual SIM phone.
Source : Micromax A100 Android smartphone with 5-inch screen listed online for Rs. 9,999
Homeshop18 link : Micromax 3G Android Full Touch Phone - A100 . Buy Best Micromax 3G Android Full Touch Phone - A100 at Lowest Price Online
princeoo7
On a Journey called Life :P
Jun 10, 2010
1,060
37
61
Mumbai
We can't expect it to be NOTE when we are only paying 9,999/- :p
Still any other specimens reviled ?????
Xavier
Mar 17, 2011
523
142
81
Pune
The resolution isn't that big a deal as most people are making it out to be. The Dell Streak, released 2 years ago, sold pretty well and had the same screen size, aspect ratio and resolution. It's just that after coming from a 250-330 ppi device, it's a little difficult to come down to a lower ppi display as things tend to look rough. However, for a first time or low end smartphone user, this won't make much of a difference. If this MediaTek processor is actually good and the display is of decent quality, the A100 should see a decent amount of success.
Shubham1401
Jan 10, 2011
371
113
81
26
If it turns out to be a good phone them i'm selling my Xperia Mini Pro... 5 Inch screen!!!
Dushie
Jun 22, 2009
490
10
82
42
Bangalore
Let some reviews come out, will get to know the performance for the same, the only worry i feel would be battery backup.
jyotsna
New Member
48
0
0
26
I guess its better to buy samsung galaxy y than 9999 Micromax A100 Android phone..!!
is not ie so..?
- - - Updated - - -
same here dushie..
the worry with micromax is that these phone have low battery backup..
however spending 9999 on micromax is quite much if we look at its quality..
its better to buy some or relevant brands..!!
gigy
Active Member
206
4
32
This is the remake of chinese N8000 I think. If so worth the money, wonder why it isn't not coming with the 2500 ma battery. Its a single core cpu.
