Budget 51-70k mild gamer rig with budget 60k without graphics card and monitor
pawannh
  1. Q: What is your budget?
    • 60K
    • CPU - Intel Q6600
    • Motherboard - Abit IP35 Pro
    • GPU - GTX 470
    • RAM - Gskill 2*2GB DDR2 4-4-4-12
    • Monitor - Dell 2407WFP-HC
    • SMPS - Corsair HX620
    • (please mention the rest in above format)
    • CPU - Intel i7-3770. Need to have atleast 4 cores (8 threads) as I need to run VM
    • Motherboard - any compatible motherboard
    • GPU - Onboard to begin with (not much in gaming atleast currently)
    • Gskill Ripsaws 2x4GB
    • Hi end Graphics card
    • Open to online purchase
    • TE Dealer
    • Yes
    • mild Gaming and VM for work
    • Media server
    • Video encoding
    • Do not want to buy XYZ company product as I heard the after sales service in India is pathetic
    • Strategy - Civilization 4
  11. Q: What is your preferred monitor resolution for gaming and normal usage
    1. Gaming - 1920x1200
    2. Desktop - 1920x1200
    • May be in future
    • Windows 7 64 bit
    • Linux - Mandriva
Is there a 'k' version of 3770? Where is it available?
---------- Post added at 11:28 AM ---------- Previous post was at 10:37 AM ----------
Can 3770 (not 'k') do any overclocking? I intend to do slight overclocking in future to keep pace with time. I understand IVY-Bridge runs hotter (it should have been over way round...) compared to Sandy bridge, only reason I chose it is because of USB 3.0/PCI 3.0 (future) and HD4000. Otherwise I could have gone with 2600/2700. Is HD4000 lot more better than HD3000? I intend to use this new rig for atleast next five years.
i7 3770-20k or more[Not available in india yet]
Asus P8H77-M-8k OR Intel DH77KC-7k
Gskill Ripjaws 2X4GB 1600mhz-3.5k
The i7 3770K or non K version is not yet available in the market so if want that then you'd have to wait for few weeks.Otherwise here's another option-
Intel i7 3820-19k[Sandy Bridge-E socket 2011]
Intel DX79TO-13.5k
Rest the same,Get a SSD with remaining budget-Samsung 128GB 2.5-inch SSD 830 Series-12k
Hope this helps.:)
Thanks Jakob! I see i7-3770 being available on hardwire.in. Any suggestion on PSU and Cabby? I'm slightly skeptical about SSD due to the failure stories I have heard about them. Is it matured good enough now to be used in 24x7 rigs where there are lots of I/O on secondary memory?
Well i didn't check hardwire.in anyway i thought you have Corsair HX620 so i didn't suggest it,Here-
Seasonic S12ii 520W-3.7k OR Corsair VX550W-4.5k
Corsair Carbide 400R-5k OR Nzxt Gamma-2.4k
SSD's are often in usage these days many members on TE itself are using it for OS and other critical application so no need to worry about that.
