Monitors Monitor Vesa Mount support
toocool6600
Can't find monitor with vesa mount support at all, no lg, samsung or any other good brand. Need probably 4 monitors for quad monitor setup, anyone know any model please?
For multi monitor suppprt u can buy standard single monitor vesa wall mounts just buy 2 200mm ones and 2 extendable ones and u will be good to go without spending 8k+ on multi monitor stand
Stands are secondary right now
Please tell me about vesa monitors first guys
i am using 3 of these http://www.ebay.in/itm/SAMSUNG-22-2...486304?hash=item3d0dad9b20:g:CF8AAOSwU~FWD5Og
as for stands 2 of these
http://www.ebay.in/itm/LCD-LED-Plas...809073?hash=item3ab2ea65b1:g:gzMAAOSw1XdUVerM
and these in sides
http://www.ebay.in/itm/ADJUSTABLE-W...040239?hash=item4b08ac0c2f:g:MhgAAOSweW5U7bUN
i am using the first stand in center monitor and the second extendable in side monitors to tilt them towards the center monitor
this is the CHEAPEST option available costing below 2k everything else is 15k++
a question why do u need quad monitors,3 monitors are great for gaming,u cant fps in quad plus it puts extra load on gpu and no wayy in hell can u manage a 1920x1080x4 without a 1080 sli +1060 physx
and these in sides
I am not into gaming, need it for my trading purposes, can you explain last line? About load and 1080 sli +1060 physx?
Or use a GPU with 2 two display ports and also get a video card for additional 2 displays?
Which option is better?
Don't get your question. almost any GPU today has got 4 ports.since gaming is not an issue u should mostly be fine.
Most monitors have HDMI and VGA do just get a dvi to VGA and
HDMI adapter and u should be good
