Most Accurate BP Monitor?
harshit143
May 11, 2009
495
119
132
27
These days i am facing a hype in my blood pressures. I own an analog BP monitoring instrument but it requires a person to check it and right now i am living alone. Please suggest me the most accurate Digital BP Monitor. There are many available at flipkart but all have mixed reviews. Though i know nothing can beat that analog one, but a digital one is a requirement now. The only thing I need is accuracy I don't need those fancy features like memory or touch screen etc.
hotshot05
Veteran
Sep 11, 2008
2,291
397
171
Kolkata
hotshot05.page.tl
Digital BP monitors are extremely sensitive. You have to take readings 3-4 times for identifying garbage values and averaging the remaining readings.
Few of my colleagues had bought Omron BP Monitors. But they stopped using it after a few months.
vivek.krishnan
Veteran
Dec 18, 2009
7,476
1,676
303
Ghatkopar, Mumbai
plus.google.com
Amen to that. What I have noticed that the wrist attached ones are the ones which give out false reading mostly. The ones which are similar to the analog style old monitors are more accurate. But nothing beats doing both - analog + digital - we have both.
vivek.krishnan
Veteran
Dec 18, 2009
7,476
1,676
303
Ghatkopar, Mumbai
plus.google.com
I have no experience with the first one. The 2nd one is what my colleague had bought.
Well, we have 2 digital and one analog. The digital ones are Omron and Analog is Rossmax I believe. The handheld one used to give wide variations - we had to do multiple readings and finally gave up on the device. We bought the analog and digital one later. No issues with either.
Reactions: hotshot05
bond_bhai
Active Member
131
41
42
Bangalore
We had Omron Digital, it was almost always inaccurate. We had to try 3-4 times and then basically see which one was closer to what it was last time! I later brought Rossmax Analog one with sethescope, its a lot better but takes time to know how to measure. I took it to my doc and guided me how to read from the device.
pauldmps
Veteran
Mar 20, 2011
1,412
240
101
27
Digital BP monitors are not accurate but I bought Omron HEM-7120 for my dad from Amazon. The readings are surprisingly good. Just make sure you discard the package provided batteries and instead install new ones. The readings will be bad if the battery voltage goes down. But again nothing beats the analog meter.
ankushv
Jul 30, 2010
543
120
81
Go for the omron . I have it . Bought it with the adapter from amazon .
