MP3 Player advice
skada
New Member
46
2
0
Hi all...
I am thinking of buying a mp3 player which should have
-FLAC support
-FM
-expandable memory (microSD)
-NO NEED for video playback
-smallest size possible
budget ~10k
WingZero
Jun 24, 2007
2,715
109
152
USA
Cowon D2 is best for that budget
get a d2 for 9k odd 8gb model and with 1k get a good earphones pl11 for 585 from amarbir is a good option or something better.
Brendon
Veteran
Mar 21, 2005
2,946
221
152
36
Or you can get an Amp3 pro2. I have that player and its amazing. Its not very intuitive as say the D2 but its not too big and the sound is mindblowing ! You can get it from Jaben.net along with a Crossroads Quattro for approx 8.5k. You can sell the Quattro for about 3k to get an effective price of Rs 5.5k for the Amp3. Its only 4 GB but supports upto 16 GB micro sd cards.
skada
New Member
46
2
0
d2 is touchy :p and ha video playback (not complaining but i may save for headphones )
a bit sturdy one should be better
I am a bit rough handler
Brendon
Veteran
Mar 21, 2005
2,946
221
152
36
Well the Amp3 is made of metal. If I was traveling late at night and was mugged I would be confident that if I use the amp3 as a weapon it would knock out the mugger and will still function ! :)
Grease Monk
Intertoob Ninja & Hamster Hunter Extraordinaire
May 21, 2005
963
42
113
35
Chennai
touzeen said:
+1 to Clip+
Is it available in india? chennai?
I saw a Sansa Fuze in E-Zone. So it is likely they will have the Clip as well.
stalker
Veteran
Mar 17, 2005
5,228
255
222
The Clip+ hasn't been launched in India. Most TE folks picked it up from the Amazon GO which KMD handled. Get in touch with him, he might still have a few pieces left over. 2k for a 2GB player
Rockfella
I love Goa
Section Mod
Mar 18, 2007
3,868
467
172
Gurgaon/NCR.
WingZero
Jun 24, 2007
2,715
109
152
USA
clip+ is small bt not at all thin...:p
Yea it does everything what it should do and more for the price:D
