PC Peripherals Mysterious Cable
Haste
Proxy Warrior
Hi,
I just found this cable while going through my old computer hardware. It was new & packed and I don't know what its for :ashamed: Does anybody know?
Regards,
hmmm...yes looking at the RF connector at one side it does seem to be an antenna cable but why the 2 earphone like connectors at other end as there is need for only one for antenna AFAIK :S
It's Radio antenna cable for TV Tuner card.... The two ends are for better reception. Basically, you mount the ends on your window or outside with two ends farther from each other to get better reception.
