Storage Solutions Nas Build Help
rushab_rdx
Hello everybody,
i wanted to build a pc specifically meant for nas and to run .!
I have a few doubts and need suggestions!!
First of all im trying to build it in 20000 (Excluding HDD)
I am currently thinking of buying
1- Intel G4400
2- Motherboard around 5000k
3- seasonic psu
4- 4gb ram
I wanted to know whould this hardware be fine if i wanted to run OPENMDIAVAULT 24*7*365 .
I will be running couchpotato, transmission, sickrage on it!
This is one another help i need is would the ODROID XU4 be good enough for the above same things?(As im on budget)
Also i buy XU4 will the power adapter provided with it will be sufficient to power up two 4tb drives? or i would need something else to power them
Thanks in advance.
