for near surface computing - i need a bigger monitor. I have got 20.1" Viewsonic 2025wm.
want to upgrade to 24" or higher.
my query is -
1. can i or should i get a LCD TV, 32" may be, and use it as a monitor? how successful is this? wat r the pros & cons of a LCD TV as near PC monitor.
2. Which one wins - a computer monitor specifically made for computing or a LCD tv as a PC monitor isn't that big compromise?
3. is 32" toooo big for near surface. resolution shall be 1920X1200. or 24" you'd consider to be the biggest optimum screen size one should use as a near surface pc monitor?
4. alternatively, would you recommend getting another 20.1" monitor and put it adjoining to my existing viewsonic 20.1" monitor?
4 questions, need some advice, opinions & suggestions.
brands i prefer - dell, viewsonic, samsung.
usage - web & print designing, multimedia, surfing etc
budget max 30K..
thanks
my query is -
budget max 30K..
thanks
