Budget 51-70k Need a 4k video and audio editing PC. Premier, Resolve, Vegas pro
sidz2bt
Questions
1. What is your budget?
2. 50-70K
* CPU - Intel i3
* Motherboard - gigabyte b250m d3h
* GPU - none
* RAM - crucial 2X4GB
* Monitor - Dell uh2311h
* PSU - antec 450
* Monitor - Dell UH2311H
* PSU - antec 450
* 4 the hdd
* CPU - whichever is good value for money for video editing
* Yes
* Bangalore
* Open to online purchase
* Yes
* Gaming
* Video/audio editing
* HTPC
* Download rig, 24x7 operation
* Watching HD movies
None
GTA V. Overwatch, Third person shooters, FPS
3. Gaming - 1080p FullHD
4. Desktop - Hull HD
- Are you looking to overclock?No
* Windows 10 64 bit
* Gaming
* HTPC
I would suggest to keep around 5K separate for a RPi or Android box and a HDD. The PC of your choice will eat power, not sip frugally.
As for the rest, you should opt for a Ryzen and if you can up the budget, a Threadripper.
Thank you for that suggestion. I have rpi 3 with omsc and as you suggested, I will use it for that. Can you please advice on the configuration of the system for my editing work?
Budget -101K
AMD Ryzen 5 2600 -15600,
MSI B450-A Pro -9800,
Corsair Vengeance LPX 16GB(8GBx2) 3000Mhz -14100,
Antec NE550M -4000,
Antec P8 Transparent Side Panel -5000,
Samsung 860 EVO 500GB SSD -11000,
LG 22MP68VQ-P 22" FHD IPS -9500,
Zotac GTX 1060 6GB Mini GPU -25300,
Cooler Master Hyper 212 Turbo -3000,
Cooler Master Masterkeys Lite L Gaming Combo -3900.
TOTAL -1,01,200.
All components prices are taken from mdcomputers.
