Budget 51-70k Need a CPU for Programming and multi tasking. Budget - 65k
raghuteja9192
New Member
Recruit
Apr 10, 2018
3
0
1
  1. What is your budget?
    • 65k (CPU)
    • CPU - i5-8600k
    • RAM - 16GB DDR4 3000mhz
    • Yes
    • CTC, Hyderabad
    • No
    • Programming
    • editing
    • medium gaming
    • Brand preferences:Intel
    • In the Future
    • Windows 10
    • FEDORA/LINUX
I will be using a dual-monitor setup.
Graphic card -
Not much important for now. Will Intel on-chip graphics be sufficient to power two 24 inch monitors with ease? If external graphics is required, please suggest.
I want to upgrade this rig in the coming years. Looking for a motherboard board that supports:
- Optical Audio out (S/PDIF)
- Great Audio
- upto 64 GB memory
- SLI (Multiple Nvidia GPU in the future)
- SSD compatibility
- Good Cooling options (to upgrade in the future)
- Not sure about Overclocked memory. How will the performance of 2666 HZ ram vs 3000/3200.
- I will not be doing overclocking on my own. If auto OC available that's great.
Mod Edit: Please use forum template
bssunilreddy
Veteran
Mar 24, 2007
1,820
716
207
40
Nellore
plus.google.com
Budget -73K
AMD Ryzen 5 1600X -17200,
Asus Prime B350-Plus -9000,
Corsair Vengeance LPX 16GB DDR4 3000MHz -14900,
Zotac GTX 1050 2GB -13300,
Corsair CX 450 -3500,
Antec GX200 -3000,
WD Caviar Blue 2TB -4600,
Samsung 860 EVO 250GB SSD -6500,
Logitech MK200 -1000.
Total -73,000.
All prices are taken from mdcomputers.in
6pack
ex-Mod
Sep 19, 2005
7,457
1,496
302
Are the 2 monitors included in the budget?
Yes, integrated Intel HD graphics support running 2 monitors. Don't expect too much from the integrated graphics wrt gaming. Its barely enough for high bitrate HEVC video.
imo, other threads have almost same budget with similar configs. Have a look at those too.
raghuteja9192
New Member
Recruit
Apr 10, 2018
3
0
1
Budget -73K
Antec GX200 -3000,
Total -73,000.
Thanks for the Quick reply :)
Could you suggest me an intel 8th gen build also please.
