Budget 41-50k Need a Home PC under 50k
papul
New Member
3
0
1
Hello. I wish to replace my 8 year old PC with a new one. I wish to buy the latest Ryzen 5 3400G CPU but I am most confused regarding the motherboard. I have a working but 6 year old Corsair 500w PSU that I would like to reuse if compatible with the new config.
  1. What is your budget?
    • 50-60K
    • CPU - AMD Phenom II
    • Motherboard - Some gigabyte motherboard
    • GPU - integrated in the motherboard
    • RAM - 4 GB(forgot vendor)
    • Monitor - Dell 19 inch 1366x768 VGA monitor
    • PSU - Corsair 500w PSU
    • PSU - Corsair 500w (6 year old but working fine. Don't know if it will be compatible with new rig)
    • keyboard+mouse
    • UPS
    • 500GB+1TB HDD
    • CPU - Ryzen 5 3400G
    • Motherboard - any compatible motherboard
    • GPU - none.
    • 256GB or 512GB SSD(any good manufacturer)
    • 16 GB RAM
    • A good 24" matte display atleast 1080p resolution monitor
    • I might add a dedicated GPU later on.
    • Open to online purchase(Amazon or Flipkart)
    • No
    • MS-Office
    • Web Browsing
    • None
    • None
    1. Atleast 1080p full HD
    • No
    • Windows 10 64 bit
    • Linux - Manjaro
vyral_143
Jarvis
Section Mod
Nov 28, 2011
3,229
1,369
207
香港
Thanks for the recommendation. Will this motherboard work out of the box with 3rd gen Ryzen 5 3400G CPU?
Nope, in this initial stage of Ryzen 3000 series processors, you would need to get it updated and most retailers would help you do it.
papul
New Member
3
0
1
I was planning to buy it
I was planning to buy it online though. I am now thinking I'd rather wait a few months for updated motherboards to come on the market.
