Budget 21-30k Need Advice for a Laptop Budget Under 30k
parag1985
Hi guys
I need ur advice for buying a laptop for my frnd.She basically needs this for all the basic things and to practice coral draw and photoshop.Her budget is under 30k and one thing she needs most is the best after sales service onsite warranty is what preferred she cant run to the service center everytime if any problem occurs .This is her first laptop so I know she would use that onsite service quite often.
Please suggest keeping above points in mind.
Thanks in advance!!
buy hp probook 4445s from ebay,best laptop built with anodized alluminium under 30k,finger print reader,light weight just 2k,super slim without losing the dvd drive, you will also get a micromax a25 smarty android phone worth 4k for free after applying coupon code during diwali
nice option you suggested but only drawback is it doesnt have any windows...
just asking does onsite warranty covers all windows related problems also...like formatting etc.
TOSHIBA LAPTOP i5011
================== CORE i3 (2ND GEN),2GB RAM,500GB HDD,15.6"SCREEN DVD WRITER,LAN,WIFI,WEBCAM, BAGPACK,DOS 512MB GRAPHIC CARD,1YR WARRANTY======28500
How good is this.
the hp probook i suggested has 3yrs onsite warranty+ it has premium looks, one can't say its a 30k lappy cuz it looks like utrabook and it makes an impression of above 40k laptop also the intergreted graphics is much better than hd 4000 or even hd 5000(whenever it comes) and its latest launched just a month ago,usb 3 etc etc etc etc just 29mm thick
How are Fujitsu lappies
Got these rates
AH531 - D/C 2ND GEN / 2GB/320GB / 15.6" = 22250
AH532 - I3 /2GB / 320GB / 15.6" = 25500
LH531 - I5 / 4GB / 750GB / 14" = 35500
AH532 - I3 / 4GB / 500GB / 15.6" = 27000
