1. Q: What is your budget?
a. 25k-30k
a. CPU - Intel P4
b. Motherboard – American Megatrends
c. GPU – 128 Mb Graphic Card
d. RAM – 2gb
e. Hard Disk - 160 GB
3. Q: Which hardware component are you looking to buy (component name). If you have already decided on a configuration then please mention the (component brand and model) as well, this will help us in fine tuning your requirement.
a. CPU - Intel i3 2120
b. Motherboard - any compatible motherboard for gaming
c. RAM – 4Gb any company
d. GPU – Nvidia 9800Gt 512 RAM
e. Hard Disk – 1Tb/700GB
4. Q: Is this going to be your final configuration or you would be adding/upgrading a component in near future. If yes then please mention when and which component
a. This will be my final configuration if something that I would like upgrade that would be graphic card and RAM
5. Q: Where will you buy this hardware? (Online/City/TE Dealer)
Delhi
6. Q: Would you consider buying a second hand hardware from the TE market
Yes
7. Q: What is your intended use for this PC/hardware
a. Gaming
8. Q: Do you have any brand preference or dislike? Please name them and the reason for your preference/dislike.
No
9. Q: If you will be playing games then which type of games will you be playing?
a. Strategy - Civilization 4
Call of Duty Modern Walfare 3, and all the latest games including Mass Effect 3
10. Q: Are you looking to overclock?
. No as I don’t much about overclock
11. Q: Which operating system do you intend to use with this configuration?
Windows XP
