TickTock110
Recruit
Q: What is your budget?
Budget is around 80k to 100k.
I m using imac
Yes, will upgrade the following within 6 months
Won't be upgrading in future
I live in Delhi and will be buying from Nehru place.
It will only be used for playing games like Crysis 2, Metro, COD, BF3 and should run any upcoming games at High-definition without any problems.
Gaming - 1920x1080
Desktop - 1920x1080
Maybe, not sure about it
Windows 7 64 bit
I'm mostly eying on Intel i5 2500k & i5 3570k, GTX 680 or ATI 7970 & Maybe any good mobo from asus, gigabyte or Asrocks.
Please advice and ask me any questions if i missed anything.
I m using imac
Gaming - 1920x1080
Desktop - 1920x1080
Windows 7 64 bit
