rdst_1
I have some time on my hands and so I was thinking of doing some metal-work at two of my construction sites.
For now I will be mostly working with angle irons in the 5-10mm range. Might also use some square tubings.
Welding, though more stronger, is going to be a bit cumbersome and will take a lot of time getting perfect at.
Since most of the frames I will make won't be load bearing, I was hoping I can get away with using nuts and bolts.
So thinking of ordering a bench/pillar drill press and get to work. Also instead of a chopsaw, I am thinking of ordering an angle grinder stand as I already have an angle grinder.
Please help me in choosing the right way and consequently the right parts to order before I get to work.
TIA.
TIA.
