Need an Inverter with Battery for Home Use.
sunnysibal
Hi Guys.
Please suggest me an Inverter and Battery for home usage..
My consumption would be 2 fans , 2 tubelights and a Television.
need a backup of at least 10 hours and it should be within a budget of 8-10k
Exide Invalubular for that budget... Get the highest Ah rating you can afford.. Higher Ah = more backup... Exide Invatubuler has long life as well...
If long life is not your priority & you want your battery to run ~3-4 years then get Amaron SHIELD. Its a ULM battery which will be cheaper than a tubular type but with ultra low maintenance albeit lesser life. Tubular battery can last for ~5-7 years (allegedly)...
You wont get inverter + battery at that budget, get 800 va sukam falcon inverter with exide inverter plus 180/200 ah battery, should cost you around 14 k including battery trolly and installation.
buy any product that hve local support, all makes of invertors are prone to failures too, also invest in extended warranty branded battery ! else money lost in few years (or months)
