tekxtinct, please fill up this
template [appropriately] and put forth your query, it will help us give you better suggestions.
Also you are new on TE, so welcome aboard and hope you have a nice experience, Cheerio!!
As you wish.
Q: What is your budget?
A: 0-20K
A: It is a preassembled CPU config from HCL around 6-7 years old. I do not know of very explicit details as such. However, What I know is given below:
CPU - Intel Pentium 4, 2.36 Ghz
Motherboard - Asus P4GE-MX
GPU - nVIDIA Geforce FX 5500 (AGP, 8x)
RAM - Transcend 2X512 MB 333Mhz
Monitor - LG Flatron W1943C
SMPS - Not Known
(please mention the rest in above format)
Monitor - Dell 2409
SMPS - If the earlier works fine, I would not require it to change
CPU -
Intel G620 Sandy Bridge (2.6 Ghz)
Motherboard - any compatible good motherboard (in similar price range)
GPU - As for now, Onboard graphics shall be sufficient. (I have picked
Gigabyte GA-H61M-D2H MoBo)
RAM -
Corsair 4GB 1333Mhz DDR3 RAM
As for now, No plans of upgrade in near 1 or 2 years. I do not need any support for USB 3.0 and all.
Kolkata, Open to online purchase
A: No
A: Browsing, Mild Gaming, Few not very PC intensive software tasks. Everyday rup up atleast 5 hours.
A
o not want to buy AMD company product.
Strategy - Civilization 4 (it runs at current config too)
Racing - Grid at medium to high settings
Gaming - 1024*720 and all.
Desktop - 1360x768
Possible, but not necessary
Windows 7 64 bit/32 bit
