Itsmeakash
Recruit
Hi ppl,
I am new to this forum and this is my first thread.I am planning to buy a pc in a price bracket of 35-40k. This is my first pc. Literally I have no/little knowledge about pc. Kindly help fellas!
1.What is your budget?
35-40k
2.What is your existing hardware configuration (component name - component brand and model)
I don't own any pc.this will be my first pc
3.Which hardware will you be keeping (component name - component brand and model)
None
4.Which hardware component are you looking to buy (component name). If you have already decided on a configuration then please mention the (component brand and model) as well, this will help us in fine tuning your requirement
Monitor-hp pavilion 22cw(based on my Google search results.suggest if there is something better)
And I looking for a mid range performance device (like i5,4gb Ram,etc)
5.Is this going to be your final configuration or you would be adding/upgrading a component in near future. If yes then please mention when and which component
This will be my final configuration.will be using it for next 4-5 years!
6.Where will you buy this hardware? (Online/City/TE Dealer)
Chennai,(open to online purchase if I could get a good deal)
7.Would you consider buying a second hand hardware from the TE market?
No
8.What is your intended use for this PC/hardware
Moderate Gaming(not a hard core gamer but will be playing NFS,gta,FIFA,cs,etc),Browsing,Downloading and Watching HD movies,saving files
9.Do you have any brand preference or dislike? Please name them and the reason for your preference/dislike.
Nothing like that.but I heard components from Asus are not reliable,amd heats a lot,etc.please educate me..confused a lot!
10.If you will be playing games then which type of games will you be playing?
Racing games like ashpalt,NFS and some statergy games.
11.What is your preferred monitor resolution for gaming and normal usage
No idea.all I want is a 22' monitor with good resolution,ips,led(heard them to be good)
12.Are you looking to overclock?
No
13.Which operating system do you intend to use with this configuration?
Probably latest versions of Windows and Ubuntu os.(dual boot possible?)
Thanks in advance.
35-40k
None
No
No
Thanks in advance.
