Budget 90k+ Need Help in Buying a PC !!!
Guys , I dont want to try Asrock boards . ASUS or GIGABYTE will be fine.
Now I am also thinking of going with a 120 GB SSD . Suggest me the best one . All the component in my previous post will be final except MOBO , GFX CARD , MONITOR .
For SSD's you have the following options --
Crucial M4 120GB ~8500/-
OCZ Vertex4 ~8000/-
Corsair Force GT 120GB ~8200/-
You can get these from this site --> Buy SSD | Buy SSD India | SSD Price | SSD for Laptop [affiliated to Prime ABGB, Bombay].
The rest of the components I suggest that you buy the following --
Motherboard -- ASUS P8Z77-M PRO
Graphics Card -- Sapphire / HIS / ASUS HD7870 2GB OR HD7950 2GB
Monitor -- DELL Ultrasharp U2312M, the eIPS-panel is far superior to the cheaper TN-panel when it comes to colour reproduction and the viewing angles though these monitors have a tendency to suffer from back-light bleeding -- Backlight Bleeding: An LCD Problem]
Hope this helps, Cheerio!
My opinion is to avoid zotac and get that MSI N670 GTX .
also op can buy an ivy bridge cpu & WD HDD .
For a beginner Crucial M4 120 SSD is the best choice .
