Budget 0-20k Need help on buying Motherboard, Processor & RAM
Kakahi
Agaliarept
131
22
37
Elelogap
Hello guys, my friend asked for my help and I need your help to help her out with the best computer parts.
*What is your budget?
15K - 18K
* What is your existing hardware configuration (component name - component brand and model)
* CPU - Kaput
* Motherboard - Kaput
* GPU - Asus Rog-Strix-RX570 4GB OC edition
* RAM - Kaput
* Monitor - Samsung 24 inch curved full HD monitor with 1800R
* PSU - Corsair TX650
* KB - Ant Esports Mk1000 LED Mechanical Gaming
* Mouse - Logitec G400
* UPS - Luminous 1.1 KVA
* HDD - WD Green 2TB, Seagate 4TB
* SSD - WD Green 480GB SATA III
* Cabinet - NZXT H Series H210
* Which hardware will you be keeping (component name - component brand and model)
* Which hardware component are you looking to buy (component name). If you have already decided on a configuration then please mention the (component brand and model) as well, this will help us in fine tuning your requirement.
* CPU - Ryzen Series (AMD only)
* Motherboard - No Idea
* RAM - No Idea
* Is this going to be your final configuration or you would be adding/upgrading a component in near future. If yes then please mention when and which component
Final
* Where will you buy this hardware? (Online/City/TE Dealer)
* Lamington Road (Prime ABGB, Maccan Infosys)
* Open to online purchase only for significant deal
* Would you consider buying a second hand hardware from the TE market
* No
* What is your intended use for this PC/hardware
* Gaming
* Do you have any brand preference or dislike? Please name them and the reason for your preference/dislike.
No preferance for quality product
* If you will be playing games then which type of games will you be playing?
* Far Cry 5 and above series
* COD 2 and online Global Offensive & PuBG
* What is your preferred monitor resolution for gaming and normal usage
3. Gaming - 1920x1080
4. Desktop - 1920x1080
* Are you looking to overclock?
* No
* Which operating system do you intend to use with this configuration?
* Windows 7 64 bit, Windows 10 pro 64 bit & Fedora
chetansha
Veteran
Jun 30, 2007
1,816
736
202
Coimbatore
Board asrock b450 pro4 - 6900/-
Proccy ryzen 5 2600 - 11,000
Or ryzen 5 3600 - 17,000
Ram - 8gbx2 - 7,000 approx.
Kakahi
Agaliarept
131
22
37
Elelogap
Thanks for your response. But, her budget is limited as I mentioned above. So, please help me here within the budget.
chetansha
Veteran
Jun 30, 2007
1,816
736
202
Coimbatore
As you have a graphic card, there is no point in going for ryzen 3 3200g; maybe you can pick up 1st gen ryzen series from forums.
nac
Feb 5, 2008
517
80
116
In this budget, this is the best by very good margin than any AMD Ryzen for gaming.
i3 9100F
B360/B365 chipset board (B360 may need BIOS update, check before you buy)
Corsair Vengeance DDR4 8GB
Reactions: gudboy
