Budget 51-70k Need help with building PC
  1. What is your budget?
    • 50-60K
    • None. I'll be building fresh. But please don't include the peripherals in the build, I'll be getting them separately.
    • NA
    • CPU - was thinking of ryzen 3 or 5
    • Motherboard - any compatible motherboard
    • GPU - GTX 1060 3GB or 6GB. need help here
    • PSU - any good PSU
    • 8gb ram. I'll be upgrading it soon as I'll start earning in a few months.
    • SSD- I'll add later.
    • SSD
    • RAM
    • STORAGE extra
    • Shillong/Guwahati.
    • Don't know if it's cheaper to get online of offline.
    • No.
    • Gaming
    • Browsing
    • Desktop Processing
    • Watching HD movies
    • Neh
    • ARK-SE
    • Racing - Grid at medium to high settings
    • CS GO
    • BF1
    • PUBG
    • Others
    1. Gaming - 1080p
  12. Are you looking to overclock? Will see later.
    • Windows 10 with Ubuntu on dual boot.
Budget -65K
AMD Ryzen R5 1500X -14500,
Asus Prime B350 Plus -8000,
Corsair Vengeance LPX 8GB 3000Mhz -6500,
Corsair CX650M -6000,
Antec P8 Tempered Glass Panel -4500,
Zotac GTX1050Ti 4GB OC -12000,
WD Caviar Blue 1TB -3500,
LG 22MP68VQ-P 22" LED IPS -9000,
Logitech MK200 KB/Mouse Combo -1000.
TOTAL -65,000.
Budget -65K
TOTAL -65,000.
Thats a good build. Though for a gaming system, it'd be better to drop the cpu down to a ryzen 3 1200(& OC the crap out of that) and the psu down to something near the 450w range since no way in hell is that system going to use anywhere near 650w. Then use the money saved to get a 1060 3gig
+1 for this. Get a GTX 1060. Even if you have to skimp on Case, HDD (using old one maybe?), PSU (a quality 500W will be more than enough)
