I am making a new machine and could use some suggestions. Its not for gaming, I wont have a video card as i only play simple games, which onboard card should be able to handle. Not looking to overclock. I will be using this for doing large builds for my work. OS will be some linux, probably fedora 27, dual boot with win7. My old haswell based pc will move to kids room. Monitor stays the same (some 20" odd led monitor with hdmi from benq).
I need some help with the PSU. I am considering the seasonic s12 or corsair tx550M. Are these overkill, will they be operating in their comfort zone. Is there a better recommendation.
I need a PSU.
I also need a large mouse. I got big hands. Any suggestions.
I also need a decent keyboard for the kids machine. not too expensive.
Here's the template -
I need a PSU.
- What is your budget?
- Open
- None
- Monitor - benq
- asus xonar essence pci
- CPU - Intel i7-8700
- Motherboard - gigabyte Z370-HD3P (has PCI, needed for my sound card)
- GPU - On board
- memory - corsair vengeance 16*2gb lpx 3000mhz
- chassis - corsair spec-03
- disks - evo 960 500gb (builds) + evo 960 256gb (OS, home, win7), seagate 2tb 7200 rpm (storage)
- PSU - ???
- Final
- Bangalore
- online
- No
- Usual Browsing etc
- large compilations on linux
- prince of persia, solitaire, minesweeper, wolf3d
- Desktop - 1440x900
- No
- Windows 7 64 bit
- Linux - fedora
