Need laptop for teacher in NGO for kids in rural areas
Godfather
Member
33
0
6
Uses will be-
presentations (not 3D i feel)
music
mails
big storage for lots of data
will have to handle quite some abuse
Having had a good experience with the previous Dell laptop and assuming their after-sales-service is still good, i was looking at Dell Inspiron models.
Please check the home computing machines in the home essentials section and let me know which one to choose.
Dell Laptops/ Notebooks - Home & Home Office | Dell India
I could pick the i3 one which is at 40K approx as intended usage will be for 3 years. Or should i pick up the ones entry level Pentium one at 28K approx or the i3 one at 31K approx as it will be enough for the type of work as i am planning to get that full 3 year warranty option and that will add to the cost significantly.
The Pentium one at 28K has better screen than i3 one at 31K? Should i select any other special option. Windows 7 Home basic 64bit they will provide is good or should i get something else/better?
Also do suggest if i need to look at some other models from some other brands. Build quality, reliability and great after-sales-service is of most importance.
sabby
Section Mod
Jun 13, 2009
2,335
312
173
Bangalore
The i2 model @31k is good enough for your usage. However, if you can install operation systemt then I'll strongly suggest to get it without any OS thus saving another 2-3k. :)
partek
New Member
Recruit
Feb 6, 2010
3
0
0
47
Hii..
considering you will be u sing the laptop in rural areas i would suggest you to go for 10" Laptops since they give u extended backup from 6-10 hours... another cheaper option is new acer Dual Core 2.2 GHz/1 GB/160GB/15.4" /DVDRW/Web Camera /Carry Case/DOS/No Blue Tooth @23K
Party Monger
Veteran
Jul 15, 2007
4,548
934
201
Get a good laptop with OS and 3yrs complete cover for them...Dell will manage the rest..
wishmaster.dj
New Member
Dec 18, 2009
338
2
0
31
dont know how dell manages its asfter sales service in rural areas. check that before going for a dell.
Party Monger
Veteran
Jul 15, 2007
4,548
934
201
THey send an engineer to your place..
sunny27
Stig's Indian Cousin!!!
Veteran
Oct 7, 2009
2,191
220
153
33
Top Gear Test Track
+1 to dell's after sales service -- go for the core i3 laptop and if possible get a 9 cell battery or an extra battery in case ur in a rural area without proper electricity.
