Need recommendations for microfiber cleaning mop!
6pack
ex-Mod
Sep 19, 2005
7,654
1,577
302
I'm looking for a good microfiber mop to clean floors without bending too much. I was going to buy the scotch brite one for 999/- but the mop refills are hard to come by and just one refill costs almost 500 rupees. Other brands like Gala, Milton, etc are costlier than scotch brite.
Their refills too are sort of generic type ones.
i saw some no name ones for 250 or so but have 2 star ratings. Any recommendations?
blr_p
Veteran
Apr 11, 2007
6,181
1,327
301
I use leifheit when the maid does not show up. They are pricey though.
Dry head
These aren't micro fiber. Wash instructions say 100% polyester but they're durable. The idea is you first dry mop and then go wet.
There are spin mops for less but i don't know about durability. Using a wet mop on a dusty floor is going to smear the dust about.
6pack
ex-Mod
Sep 19, 2005
7,654
1,577
302
Wth? Almost 7k!! o_O
I'm poor guy. I'm looking at something less than a thousand.
