Need, suggestion for Modem+Router for BSNL Broadband connection
magesh85
Hi Guys,
I am going to get BSNL Broadband connection. They have asked me to buy the Wifi Router.
1. I need to get a modem+Router, correct?
2. Can you suggest a Good Modem+Router for BSNL..
Cheers!!!!!
Dlink DSL 2750U is a good choice. Else the TPlink w8968.
However, do check with bsnl if they are going to provide you the modem. In that case, just a wireless router would suffice.
How does the TP Link W8960 compare with the W8968? TP link advertises that the former has 2 x 5dBi detachable antennas. Even I am looking at an alternative to the 2750U, because mine has developed some annoying problems. After a powercut, very often, the router will just be on (power on light is illuminated) but no DSL link or wireless network at all. I have to manually power off the device, and then switch on the power after a couple of minutes. Then it will work normally (not all the time, though).
@vyral_143 Well, it seems even BSNL wont be able to provide a steady internet connection to my home.. :( so thanks guys for the suggestion but its just information for me.
