Budget 0-20k Need to upgrade my PC for medium to high settings Gaming.
ron028
Member
26
10
6
Hello guys, here is the specification of my three year old CPU
Operating System
Windows 7 Ultimate 64-bit SP1
CPU
Intel Core i3 4130 @ 3.40GHz 45 °C
Haswell 22nm Technology
RAM
4.00GB Single-Channel DDR3 @ 798MHz (11-11-11-28)
Motherboard
Gigabyte Technology Co. Ltd. H81M-DS2 (SOCKET 0) 37 °C
Graphics
DELL E2014H (1600x900@60Hz)
Intel HD Graphics 4400 (Gigabyte)
Storage
931GB Western Digital WDC WD10EZEX-22BN5A0 SCSI Disk Device (SATA) 39 °C
Optical Drives
HL-DT-ST DVDRAM GH24NSB0 SCSI CdRom Device
Audio
Realtek High Definition Audio
I want to play latest games at medium to high settings at 1600x900 resolution, please suggest accordingly, my budget is 18-20k.
PHOENiX117
Veteran
Oct 30, 2015
1,040
294
96
Operating System
CPU
RAM
Motherboard
Graphics
Storage
Optical Drives
Audio
to start off, which PSU do you have? budget psu's are an absolute NO for gaming.
i refuse to believe 4gb ram speeds can be 798mhz, you sure its not 1333mhz?
get more sticks of ram for around 2k, 1300-1600mhz atleast, 2 1600mhz 4gb sticks would be great, dual channel 8gb ram.
currently gpu prices are at an all time high due to cryptocurrency mining, i suggest waiting for a month or so, then buying an rx480/580/470/1060 for around 15-16K
Psycho_McCrazy
My suggestion would also be in-line with what Phoenix said, PSU, RAM and Graphics
Get a good PSU that can handle stable running of a decent to high powered graphics card.
I think the RAM that is shown is DDR3-1600 (runs at 800 MHz double pumped, shows 800MHz in CPUz etc.)
so adding atleast another 4GB stick should do the trick for a balanced update, and you can use your current RAM stick too. (The motherboard has only 2 slots.)
Thirdly, adding a dedicated graphics card in the PCIe x16 2.0 card (that's the spec as per the motherboard page) should give you an insane increase in graphics horsepower.
As suggested, any RX470 and higher card can handle any game you want at 1600.900 resolution, but yeah, graphics cards, especially AMD are crazy expensive. Better to wait, or even grab up some good offer at the marketplace here if you don't mind used h/w.
Psycho_McCrazy
Yes, to run dual channel stably, the Latency Settings (11-11-11-28) should match.
You can get the same brand and model/spec again to match the timings and speed, but that can be a difficult job...
Getting a dual-channel kit (tested, matched pairs) is the best, and you can definitely sell off your current RAM stick and get a matched pair Dual Channel kit.
bssunilreddy
Veteran
Mar 24, 2007
2,066
798
207
40
Nellore
plus.google.com
Operating System
CPU
RAM
Motherboard
Graphics
Storage
Optical Drives
Audio
Get this: https://www.mdcomputers.in/graphics-card/zotac-gtx-1060-mini-6gb-gddr5-zt-p10600a-10l.html
Reactions: Marcus Fenix
Emrebel
Active Member
Nov 14, 2016
316
86
42
Good choice for the budget and OP's PSU.This would last for quite a bit of time at 1600x900
However the CPU would be a bottleneck but OP can upgrade it after some time down the line
bruh...
His total budget is 18-20k
Crapmypants
Dec 13, 2014
866
343
101
I have Corsair CX430 v2, and RAM speed is 1600MHz, i dunno how it shows 798MHz
that's how the memory works - DDR stands for double-data-rate.
Do i have to search same RAM stick because i heard some latency should be same in dual channel RAM stick. Can i just sell the current one and add new 4x2 GB RAM?
i know that ram dimms with different speeds will operate at the slower of the two - not sure if this applies to latency timings too.
if you're considering a used gpu then be sure to get one with at least 6 months left on the warranty (a year pref.)
